跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
ipad mini not working after falling in water
hi
I cracked my iPad mini and then got it repaired and put a case on it without realizing that the screen was not glued on properly, so I accidently dropped in water and the iPad shut down. I tried to turn it on and for a second the apple sign appeared and suddenly disappeared, the second time I turned it on there were lines on the screen.2 seconds later they also disappeared and the iPad never turned back on. I then took apart my iPad and dried all the water I could see, but still, my iPad did not turn on. so what shall I do? IF MY IPAD CANT GET FIXED IS THERE A WAY I CAN GET MY DATE OFF MY IPAD?
a. change my battery
b. change the LCD
c. change the port where you connect your charger in
THANKYOU
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
okieday so a bunch of things. :p brace yourself for information overload ^-^
1) Regardless of the Type of adhesive the people who repaired you device use, ipads are not waterproof. this would have likely happened regardless of the screen replacement.
2) Water in its purest form (H2O), is non conductive. meaning it will not cause issues with the electronics. it is the minerals inside the water. Calcium, Lime, Zinc, Nickel, all reside in tap water, lake water, rain, ETC. these are what cause problems with electronics. All drying out the device does, is remove the H20. the remaining minerals stay on the board. we call this, Corrosion. This is conductive, and erodes the device.
a) First step, would be to buy a bottle of Isopropyl, (99% Preferred) and sumberge the mother board into it. for 20 minutes. Alcohol is non conductive, and will break down the corrosion. be sure not to sumberge cameras, or microphones into this, as it will eat away at the more sensitive components in it. standard board components can withstand the abrasive nature of the alcohol.
b) Remove the board, and scrub at it with a toothbrush. (soft bristle) everywhere on the board, while it is still wet from the alcohol. After a good scrub, dip it in, and sift it around in the alcohol. this will rinse off the board from any other corrosion.
c) dry the board. set it out, and let the alcohol evaporate, or for quicker drying, a low setting air blower will disperse the alcohol until dry.
d) Reinstall board.
e) be sure to charge the battery with an external power supply, 5-10V. (Short circuits drain batteries rapidly.) Hold the supply leads to the battery's corresponding traces for 10 minutes. This is called exciting the battery. ----eii) If this doesnt work, the battery may be fried, and needreplacing.
f) if all the above does not work, the Electronics in the motherboard have likely fried out due to the corrosion, and replacing the device will be cheaper than repairing it.
Most common mistakes by End users, that they dont know will harm the device
1) RICE: do not use rice to dry out electronics. not only is it the slowest way to dry it out, as explained above, it doesnt actually fix water damage
2) Powering on the device after submerging device: it is our instinct. "please work please work please work." Yes everyone does it. however, once that electricity is exposed to a short circuit, it substantialliy increases risk factor of damage.
3) Beleive because its working now, it will not fail later on: Water damage is corrosion on the board, those minerals expand, crack, and powder inside the device. it is always suggested to remove the corrosion as soon as you can. it is easiest to do while the device is still wet.
这个答案有帮助吗?
得分 3
3条评论:
Hi Scott, good recommendations. However, I don't believe we should be encouraging non techs to be overcharging Li-ion batteries. These batteries require tight tolerances on charge voltages and over charging them can cause serious damage to the battery and everything else if it catches fire.
According to BatteryUniversity.com:
http://batteryuniversity.com/learn/artic...
Lithium-ion operates safely within the designated operating voltages; however, the battery becomes unstable if inadvertently charged to a higher than specified voltage. Prolonged charging above 4.30V on a Li-ion designed for 4.20V/cell will plate metallic lithium on the anode. ... The cell pressure rises and if the charge is allowed to continue, the current interrupt device (CID) responsible for cell safety disconnects at 1,000–1,380kPa (145–200psi). Should the pressure rise further, the safety membrane on some Li-ion bursts open at about 3,450kPa (500psi) and the cell might eventually vent with flame.
完成的
I agree with Minho @refectio excellent answer but leave the battery part out . Playing with lithium batteries is asking for trouble. Always replace a damage lithium or shorted battery its not worth the problems it can cause
完成的
my apologies. i use this technique regularly at my location. never through extended times, and always with a variable amperage. i suppose i should have mentioned to make sure that the external power supply would need to have an adaptive amperage to the battery. that was my mistake. thank you for catching it.
完成的
添加一条评论
添加你的答案
rahman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 2,708
