跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone rebooting after battery change
Hello
i got an iphone 5s which reboots constantly , when i checked the battery i saw that it was drained
i thought that the problem is from the battery , so i changed it
then i tried to start the iphone and it is still rebooting constantly
i tried to restart the iphone by pushing the power and home button , still reboots constantly
i also tried to restart by pushing power button and volume up , but it still reboots constantly
Then , i tried to get it on recovery mode to restore from itunes, but i couldn't , it still reboots , but here there was a red screen that shows for 1 sec at the end when it decide to reboot again , this red screen only happened here not the previous cases
i think the problem is software , can't get it on itunes mode
do you agree that it's software problem ? and can you help me please get it on itunes mode ?
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you saying Apple logo then off and turn on again and off?
If yes how many seconds exactly on Apple logo before it does it again?
Try DFU mode or recovery mode keep holding home button while plugged in on Apple logo to go to iTunes recovery logo screen.
完成的
@benjamen50 thank you for your respond
yes i mean apple logo and then off and turn on again
16 seconds the logo stays on and then turn off
yes when i try to get it in iyunes mode it gives me the logo first for 16 seconds , then a red screen for 1 sec , then turn off and turn on again
完成的
添加一条评论
1个答案
已选择的解决方案
There are a few failures in the device that can cause this.
1) Battery: I know you said you replaced the battery, however, there is a chance the battery you received has gone bad.
2)Powe button short: A short circuit on the power button, may be causing it to think that it is continually being held down. Replace this component to fix that issue
3) Software: The software may have become corrupt. Put the device into DFU mode, and reload the software.
-a) Unplug the battery.
-b) Plug the device in to the PC, and replug in the battery after
-c) Press/Hold power button until Apple Logo arrives.
-d) Continue holding the power button, and hold the Home button until apple logo disappears
-e) Let go of the power button, but keep holding the home button until compute begins installing drivers
-f) follow instructions on iTunes to reload software
4) Modular Short: A short circuit on a modular component may be causing confusion in the voltage levels of the devices. Try removing everything besides the required components for boot, (Screen, Power button, and battery) If that doesnt fix it, swap the power button, with charge port, and try booting it by plugging in the device.
5) Motherboard: The mainboard is your last possible failure. Check for any physical damage under a microscope (Suggested 10X). if none is found you likely have an internal failure of an IC, and it would be more likely that replacing the device is your last option.
这个答案有帮助吗?
得分 3
4条评论:
hey Scott , thats a great feedback ,thank you
i unplugged the battery , connected the phone the pc , then connected the battery again , but before i press the power button , the iphone turns on , its probably a short in power button right ?
完成的
not really. the device, once battery plugged in is reading the power from the port, and booting it, as apple has designed it to do. in this case, you need to hold the button down, AS you plug it in. this was my fault in generalizing the statement for all devices. apple is slightly different.
Hold power//Plug in/// wait for apple/// Hold home button///wait for black///release power/// wait for device Driver install.
the way to see short in power, is to plug battery in, While NOT plugged in, as long as you have enough battery juice to boot device. if it boots without power being pressed, its a short in the power button.
完成的
oh it's ok
i did as you said , pressed the power button as i was plugging to pc , but it still reboots
also when i plug the battery , without plugging to pc , it doesn't turn on till i press the power button , so it's not shorted
and i tried the battery on another iphone 5s and it works fine
i will try to check the motherboard and also unplugging all except the screen , power and home
thank you so much
完成的
Last time I got red screen was because of the front camera assembly going bad. So I recommend you have the front camera cable unplugged before you try turning the phone on again if you get turn on and off red screen on shut off. If not try unplugging anyway.
完成的
添加一条评论
添加你的答案
Hesham Adwan 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 24
过去 30 天: 82
总计 6,726
