跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Error 9, need to recover data.
My own 5s decided it was going to go into a boot-loop. I was playing Egg,Inc (it is the best game ever) and my battery died. i plugged it in and a half hour later i returned to a iPhone 5s at the apple logo, but them i found out it was a boot-loop. Before it would boot up if the front camera cable was unplugged, but that doesn't work anymore. I really need to recover data from it. When i update, it shows error 9. Same with restore. it will say extracting, preparing, waiting,preparing,waiting, then it will fail. How could i get it to power up one last time to backup my game? Ive already tried heating the nand, putting pressure on it, etc. and it still wont restore/boot up. ive tried to update/restore without lcd and it still does this. Please help!
UPDATE:
Now it does not turn on after heating the NAND. PP5V0 and VCC_MAIN are both there. This thing is probably screwed up beyond repair.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
I was going to say, sadly too late, that heating NAND's or any other IC is generally not a good idea.
When you heat an IC, the heated solder balls expand. When there is underfill involved, it holds down the IC rather than let it float up on the expanded solder balls. The expansion has nowhere to go and they can either short out amongst themselves or explode out from underneath the IC. If you see tiny solder balls around the NAND, then that is why.
Were you using a genuine Apple Lightning cord?
There could be problems with one of the power rails. (there are dozens of rails in an iPhone), specifically the NAND related one. It could be a defective NAND or just a bad connection, in which case you could remove the NAND, clean up the underfill, reball the IC and re-install.
这个答案有帮助吗?
得分 2
7条评论:
I tested the voltages and they are there. The phone actually was on; just in DFU mode. Now I just need it to work, I don't really care about my game anymore. I am restoring and will tell you if it works.
完成的
Also yes it is a genuine Apple cord, it use it for my iPad too.
完成的
If I Reball and reinstall the NAND, will my data be there?
完成的
It just gave error 4005, it's on the same page as 9 on the apple website. Guess everything is pointing to the NAND now...
完成的
After cleaning underneath the NAND and desoldering it, I need to solder it back on but ran out of flux... Figures. It looks very clean though, also figured out why the gyroscope/compass didn't work, U18 was missing and I think it was making everything else not working right.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 511
