跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone 6 Plus sporadically turns off <60% charge, bad battery?
Good afternoon,
I have purchased an iPhone 6 plus on eBay from a reputable seller. The phone was not 100% new but I was advised it was a stock model and in good condition. When I received the phone (without retail packaging) I had no indication to think otherwise, it did not even have a scratch on it.
I've had the phone for about 2 months and a strange issue began to surface. For some reason, when the phone's battery is below 60% and I use it outside to take a picture or watch a youtube video, it completely turns off. The phone will not turn back on unless I plug it into a wall charger. It does not have to plugged in for long, even for ~5 seconds is enough. It's almost like a car with a dead battery that needs another car to help it jump-start.
When the phone turns back on it shows the same battery level as when it died, i.e. is not at 5%. I should also add that this does not happen every single time, but I would say it happens over 50% of the time, which is obviously too much too tolerate.
I read through similar iFixit forum posts about battery issues, so here's my question: does it sound like an old battery issue or a damaged tristar ic (or something else?). The phone came with a brand new and, from what I can tell, genuine Apple charger, although I cannot vouch if a non-apple charger has been used with this phone in the past.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Most likely battery just needs to be replaced. Try that first because it is the cheapest option.
这个答案有帮助吗?
得分 3
1条评论:
Thank you for your reply. Probably a rhetoric question but... The iPhone 6 plus batteries sold on this website are authentic batteries?
完成的
添加一条评论
Hi there ll be 2 issues
1. Try with changing New Battery
U can Go Through The Link For Genuine Battery
iPhone 6 Plus Battery
2.There ll be issue with U2IC Issue on Board Level or Restore the Device
Hope it Works
Thanks
Varun
iPhone 6 Plus Battery图片
产品
$29.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 258
