Should you use alcohol wipes on iPhone screen?
I bought a tempered glass screen protector and it came with alcohol wipe to clean the screen before putting on the protector. I have seen many videos of people using these wipes to clean their iPhone before putting on the screen protector. However, i have been searching around on the net if you should use this or not. Every page i visited said that you shouldnt use it because it will make the oleophobic coating go away.
I used the alcohol wipes on another iPhone i own, and still if i cant confirm that the oleophobic coating has disappeared, because the screen protector is on top, i dont have any problems. But if i would eventually remove the tempered glass screen protector would my iPhone be missing the oleophobic coating, even tho alcohol evaporates and that the screen protector alcohol wipes contain so little (rubbing) alcohol???
Just give everything about that to me.
I need to know!
3条评论
do you clean with alcohol on your iphone x doesn't damage your iphone?
由 Gabriel 完成的
I need help when I call someone I can not ear anything on my speaker
由 Gabriel 完成的
@Gabriel It is customary to start a new question. And the new answer to it will be helpful to you and others searching after you.
由 Tocki Cohi 完成的
