跳转到主内容
Asus ZenPad Z8 Model Number: P00J Released June 2016 Verizon exclusive. Asus ZenPad Z8 is powered by a 1.4GHz hexa-core Qualcomm Snapdragon 650 processor. It comes with 2GB of RAM.
2 个问题 查看全部
Setting up email signature in ZenPadZ8
Can anyone help me get a signature set up in email (pop3 - not gmail) that is more than 1 line? The field for Edit Signature is a 1-line field and no return key. I've looked at keyboard settings, I've typed out all the info on the one line (it runs all together on a test email), and I have typed it out properly and cut and pasted into that field (same thing - all run together on one line). I have chatted with ASUS who lieterally told me they don't help set up email. I have the email downloading fine, I just need help configuring the table to accept a 5 line signature.
Help?? :-)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
usually you cannot modify it more than past that, there are 3rd party apps that you can use to get better signatures with more lines of information images etc. into your signature but natively the system wont allow for it.
这个答案有帮助吗?
得分 1
3条评论:
Can you suggest a 3rd party app? This was a surprise for us as it's replacing a Samsung tablet that had no problem doing a 5-line business email signature. Thank so much for the help!
完成的
you can use either of these they should work for you, depending on how elaborate your signature needs to be https://play.google.com/store/apps/detai... or https://play.google.com/store/apps/detai...
完成的
Thank you so much!
完成的
添加一条评论
How to Create Gmail Signature on iPhone and android
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kathleen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 90
