跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
not charging or recognized
my iphone started discharging quicker then normal but would charge, recovered twice from full discharge to 100% but not anymore no response changed battery and moved motherboard to a different frame and lightning connector, any ideas? regards
(did the home and power button thing)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Hello Mar. At this point, having changed the battery, insured you have a genuine Apple charger and swapped your MB into a known-good device, it is safe to say your issue is with the charging circuit on the logic board. This is commonly referred to as U2/Tristar.
This is a micro-soldering repair and is not DIY. If you don't have the right tools or skills, I would encourage you to find a micro-soldering repair shop to do this for you.
这个答案有帮助吗?
得分 2
3条评论:
afraid of that, thanks
完成的
could that have ruined the earlier batteries?
完成的
That's hard to say. Your phone is old so the battery was probably on its death bed anyway. The Tristar IC is more of a communication chip even though it's always associated with charging problems. It is responsible for recognizing anything connected to the Lightning port. So when it fails, it doesn't recognize that a charger is present.
The actual "charging" IC is Tigris. If it was supplying incorrect current or voltage to your battery then yes, it could have damaged the battery.
完成的
添加一条评论
Try a known good battery, are you using an original apple charger or an aftermarket one?
这个答案有帮助吗?
得分 1
添加一条评论
Hi your charger may be faulty try another charger.
这个答案有帮助吗?
得分 0
1条评论:
thanks done that is also not recognized by itunes
完成的
添加一条评论
i would say just a new charger but if you already tried that then what i do is i just get a small pin needle and just poke around in the charging port for a while and dig out lint or even wood yes ive seen some wood in a charging port and just clean it out really good then try it and if not i would just put in a new flex cable charging port in it and try
这个答案有帮助吗?
得分 0
3条评论:
thanks done that, cleaned contacts with isopropyl, no go
完成的
ok we are a bit further, bought a new iphone 5, interchanged motherboards and success downloaded my movies overnite the phone discharged completely again so it seems a short in the motherboard? any possible remedy?
完成的
honestly when it comes to logic boards i dont have a clue a bad board is a bad board just check the contacts and make sure they arent bad if they look fine it goes into the stuff i dont mess with sorry man
完成的
添加一条评论
This sounds like logic board issue i.e. u2 charger ic needed to replace, this can not be done by you, so you have to take to mobile micro-soldering repair shops.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mar Schrammeyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 134
