跳转到主内容
The Samsung Galaxy Ace is a low-end, slate-format Android device released by Samsung on February 2011. Identifiable by model numbers GT-S5830(i, B, C, L).
31 个问题 查看全部
Getting Problem in hotspot in Samsung Galaxy ACE
Getting Problem in Samsung Galaxy ACE
I am getting problem in Samsung Galaxy ACE and the problem is in Hotspot. When I turn hotspot on and connects other devices, then my data network setting are automatically turned off and I lost data network. Then suddenly it goes on for few minutes and the again turn off. This is very annoying tubemate.
Please help me out of it, either in fixing this issue or I change the handset.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Try changing the following setting and see if it resolves the problem for you.
Not sure re your phone but go to Home > Settings > Wireless and Networks > WiFi Settings > WiFi (here is where I am not sure whether you have to tap the right hand soft key below the screen to get to the Advanced options box or if there is an icon for more WiFi settings) tap on Keep WiFi on During Sleep > and select always.
What may be happening is that when no data is being sent and the phone's sleep setting comes on (turns off screen to save power) the WiFi shuts down to save power as well and then when data is sent has to re-establish the connection before it can do so.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
HRWebSolution 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 12
总计 122
