跳转到主内容
由华硕制造的笔记本电脑。
2520 个问题 查看全部
Blank Screen after boot
Hi everybody
After I boot up my zenbook(UX32LN), nothing show on screen.
However, the power light, the caps lock light, and the fans was running without problem.
I tried to connect to external monitor via HDMI port but nothing out.
Anything I can test more? I just guess that there are problems with graphic card or monitor...
Any suggestion is appreciated....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Try VGA
完成的
Thanks for your reply.:)
The UX32LN only provides HDMI & Display port for output.
I tried both but still not work.:(
完成的
添加一条评论
1个答案
Hi,
Have you tried the torch trick to see if there is a display on the screen?
Shine a torch at an angle close to the screen and see if you can detect the "desktop" (once you think that it has fully booted into Windows). If you can it may be that there is a backlight problem. I know you said that there was no external display either but this is just in case you have 2 separate problems. It only takes a bit of time and at least you have eliminated it if it still fails.
If you see a display using a torch, can you try to get into BIOS on startup? This is just to see if there is a display or not or if you need to use the torch as well.
If you can't see a display at all when using a torch and there is no external display either, then there most probably is a problem with the GPU or the motherboard
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your reply:)
Still no display using torch
I found that the screen was flashing after boot for a few seconds then go back to blank screen again...
完成的
添加一条评论
添加你的答案
CKLFish 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 511
