跳转到主内容
The HTC Desire 626 is a mid-range Android smartphone released by HTC, a Taiwanese consumer electronics company, in March 2015.
15 个问题 查看全部
HTC Desire 626 Will Not Charge Or ReBoot
My HTC Desire Is Not Charging. In the past, I have had to do a soft reset (volume button and power button) however, it is not showing that screen anymore. It just saying Battery 0%. Now, I have had the battery charging all night and nothing has changed. Any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
have you had to wiggle the charger previously to get it to charge? what is the battery voltage?
Update (01/26/2017)
use a multimeter set to voltage mode. if you have a universal battery charger you could charge it up for 15 minutes or so and that ought to get it up enough to work in the phone again if the voltage being too low is the issue. has to be at least 3.5V to charge in the phone, anything lower and it will not be recognized in the device.
这个答案有帮助吗?
得分 0
2条评论:
No. And how do I find the battery voltage?
完成的
The Voltage of the Battery (appears on the label) is 3.85v.
完成的
添加一条评论
添加你的答案
Nai 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 1,091
