跳转到主内容
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 个问题 查看全部
xperia z3 blank screen after trying to repair it after it got wet
Hello
so last summer i tryed to take pictures with my z3 under sea water. bad idea.
the phone showed an overheating alert and then shutdown.
after opening it and drying it the phone started again. i could hear everything, the vibrator works, the camera seemed to work everything seemed to work except the screen and degitizer that were blank.
in my attempt to repare it, i changed the screen, then the flex cable then both of them.
needless to say nothing changed still blank screen.
can you guys help me figure this out
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
unfortunately something may have blown or shorted on the logic board of the phone. if you can look very closely at the logic board and see if anything on there is out or wack or blown.
这个答案有帮助吗?
得分 0
添加一条评论
nothing looks burned or swollen in the visible parts, but i didn't take down the metal boxes on top of the cpu and gpu
这个答案有帮助吗?
得分 0
添加一条评论
so no even under the metal boxes there is nothing that looks suspicious.
这个答案有帮助吗?
得分 0
添加一条评论
i had this problem too i put my phone into the bowl for 3 minutes and everything's fine until about 4 minutes later the screen went blank and i touch the screen and it vibrates but nothing shows only the green lights blinks and the alarm rings but the screen gone blank can you guys help me
这个答案有帮助吗?
得分 0
1条评论:
no, its the gpu, xperia 3 has a fragile gpu (i tried to change everything, but on xperia forums people complain about the gpu burning too easily) so you have to change the motherboard
完成的
添加一条评论
添加你的答案
salem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 138
