跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Polarization direction of the iPhone 6 Plus LCD Screen sold on iFixit
I have a question regarding the "iPhone 6 Plus LCD Screen and Digitizer Full Assembly" that iFixit sell. Could you tell me on which direction the screen is polarized? Is it like the original screen that is on a diagonal pattern?
I'm asking this because i bought another screen and it was vertically polarized, and on it the screen go black when I'm using my polarized glasses. Right now I can only use my phone on landscape position while using my glasses. On the original screen it would just fade a little but I could still see the screen wither on landscape and normal position.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Found more info about the subject, but still no answer from the one on the iFixit product.
http://www.etradesupply.com/blog/why-you...
完成的
We ended up at a second local repair shop. The kid working there said polarized lenses would NOT be an issue. My wife agreed to the repair and the screen is viewable with polarized lenses. Not all replacement glass is created equal. Our problem was solved.
完成的
添加一条评论
1个答案
已选择的解决方案
The one I purchased recently is horizontal. I would take into consideration the possibility the iFixit may use more than one vendor, and may change vendors over time. In addition the parts the vendor is using may change from lot to lot as well depending on pricing and availability. If I where you, I would buy one, and be your own judge. Worst case scenario you end up paying the return shipping if you don't like it.
这个答案有帮助吗?
得分 0
3条评论:
I will research a bit more about this, sadly i'm outside USA, so return the product is not a viable option for me =/
完成的
How intense is the polarization? Is it such that you cannot see the screen at all (if phone is vertical and you're wearing polarized sunglasses)? This is a major issue if you're planning on using your phone to play / control music in your car - or use maps in vertical mode... Or if you're outside on a sunny day and, god forbid, want to take a photo with your phone in portrait mode.
完成的
@raffibag It's not enough to cause major visual distortion at any level.
完成的
添加一条评论
添加你的答案
rudypetter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 3,414
