跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 stuck on spinning wheel under booting
Hey
-- BACSTORY, MAY NOT HAVE ANYTHING TO DO WITH ANYTHING -- I changed my friends screen and battery a while back, and everything worked fine - he then dropped it and the the two plastic mounts, the hex bolts holding the screen in place screws into snapped off. So the screen couldn't be held down. He decided to use it anyway.
Then the problem:
Suddenly while using it, it decided to reboot, but under booting up it would just stay on the apple logo and then go out saying it had to be charged - when in a charger it kept buzzing(two buzzes like when you plug in the charger) on the apple logo. I thought it was battery related, so I plugged in a spare one, and it went to that spinning circle instead but still buzzing and not going any further. I tried with another screen, and still the same. The coumpuer sees it as a functional phone as iTunes askses for a password on the phone to access it, but since that's stuck on the spinning circle, I'm not able to reset it.
I can't force reset it in third party app since it's seen as a functional phone.
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
DFU mode - restore - hopefully its fixed, if not take it to your local hardware repairer.
这个答案有帮助吗?
得分 1
3条评论:
It can't go to dfu mode - it's a scrapper if I can't get it fixed
完成的
It should be able to go into DFU mode, DFU mode can only be booted if a charging cable is plugged in via computer or charger.
Make sure you hold home button before apple logo when plugged in to enter recovery mode at least when apple logo appears.
3UTools software has info on how to do it and the software is useful for software restores.
完成的
Problem is, it dont respond, it have to be seems by iTunes, but for that to happen I have to say okay on the phone, which I can't - I've tried doing it multiple ways.
完成的
添加一条评论
添加你的答案
Emil Wang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 712
