Why my phone is showing an error message while switching the phone?
my phone suddenly got switched off and from then, when i am trying to open it, its showing an error message -"ERROR:unable to find a bootable option. press any key to shut down."
This is probably due to a problem with the OS. I would recommend using the Nokia Software Recovery Tool to re-install the factory image. It can be downloaded direct from Microsoft here: https://support.microsoft.com/en-us/help... It's fairly simple to use. Please let me know if you have any questions. I hope this helps.
Good Luck,
Chris Williams
这个答案有帮助吗?
its was helpful to some extent...
but while installing the software it says-"the software is not correctly signed or not signed for this device".
I'll look into that further. I've never run into that problem myself.
Got any solution??? Please reply
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,074
