Difficult to hear on earpiece speaker
Hi
It is very difficult to hear a phone call from the earpiece speaker on my iphone 6. No problem hearing when switched to speaker mode.
Would changing the earpiece speaker solve the problem ???
Thanks.
First I would check if the top speaker filter is blocked on either side including the filter on the earpiece speaker itself. To check that you will need to take the screen off and front camera to check.
Guide to check via here:
这个答案有帮助吗?
Most Of The iPhone 6 Has Common Issue Ear Speaker very low voice
Don't Change the Speaker
Just Replace The Ear Speaker Filter Or Mesh
or U can Just Clean With The Brush On Top Of The speaker i mean on the display
Hope It Works
Thanks
Varun
这个答案有帮助吗?
Take a toothbrush or similar and dip in isopropyl alcohol, brush the ear speaker shield (don't know the correct english word for the grid thingy) from outside with a circular motion. If you have compressed air in a can that can also be helpful. If the speaker is very clogged this doesn't always help though and you will have to remove the screen, front camera/sensor-shield and -flex cable to get all the dirt out. A speaker replacement is seldom necessary.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 258
