跳转到主内容
加入维修社区 - 创建账户
第二代 Moto X(市面上延用Moto X名称)由Motorola公司开发的安卓智能手机。于2014年9月5号发售,它是2018年Moto X初始版本的继任者。
Overheating after screen replacement
So this will be the second Lens/LCD assembly we've ordered for this device due to the first replacement screen cutting off randomly and getting hot while turned on/charging/post testing device. So we ordered a new Lens/LCD assembly expecting a defective part on the first go. Round two, I've made sure to move all the protective tapes from the old screen to the new assembly and any other pieces of components that were in the old screen but not the new one. The phone is still heating up pretty seriously and cutting off from time to time after everything is put back together. Am I missing an important step that's causing a bad ground resulting in the overheating issue? At check-in, the receptionist made note of slight heat coming off of the device in its original condition, although the customer vehemently says overheating was never an issue. Anything would help. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
refund customer and install their old screen. hold your ground about the phone being hot when brought in. stay calm even when customer gets angry, easier said then done but at this point, it's not your fault, unless you bent the board when taking it out originally and damaged something under the emi shielding. if you did not then you're trying to avoid a negative review and hope the customer still keeps faith in repair.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Steve B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 376
