跳转到主内容
加入维修社区 - 创建账户
Huawei P9 Lite 的维修指南和支持,发布于 2016 年 4 月。
Reboot loop after replacing Display
I replaced the broken screen on my Huawei P9 Lite, everything went fine, the display is working.
Problem is the device is stuck in reboot loop now. It restarts as soon as de Huawei Logo appears. I already tried launching into EMUI and made a factory reset - didn't help.
I don't understand what could have caused the issue?
Thanks for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
6个答案
已选择的解决方案
The back facing camera was the problem. I detached all flat cables and tried attaching them one by one. As soon as i attached the back camera the device wouldn't restart though.
I'm still wondering what is wrong with it, or how I damaged It while replacing the screen but at least I know what was the problem.
Thanks a ton richard for your help!
这个答案有帮助吗?
得分 0
1条评论:
I have a problem with my phone is it's stack on a Google account.i don't remember it please help
由完成的 分享
添加一条评论
have you tried the old screen? if old screen allows normal boot, problem is with lcd or digi IC on the new part.
Update (01/26/2017)
if you have access to a microscope id check for any parts that have come off the board. if you have another board to compare with it would be good. i suppose you could try to flash the phone with a rom and see if that makes any difference.
这个答案有帮助吗?
得分 2
1条评论:
hi, thanks for your answer, i just tried the old screen as you suggested. but the problem also exists with the old screen. any further ideas?
由完成的 分享
添加一条评论
最有帮助的答案
what is your battery voltage? and are you sure the power button is working properly?
这个答案有帮助吗?
得分 2
1条评论:
the battery voltage is 4.4V as far is i can tell (the NFC sticker is glued to the battery). i'm sure the power button is working correctly as i can power the device on and off as well as access the factory reset menu etc.
由完成的 分享
添加一条评论
I have same problem without mean camera the device working but with camera boot loop help pleassssss
这个答案有帮助吗?
得分 0
添加一条评论
my p9 lite it just go on and off itself i dont know anyone help plz?
这个答案有帮助吗?
得分 0
添加一条评论
Hi all,
I have substituted the display and the battery of my P9 lite and got the same problem: the phone turns on and is stuck in the Emui recovery mode where three options appear.
  1. Reboot system now
  2. Wipe data/factory reset
  3. Wipe cache partition
Nothing changes even after trying all three options. It just comes back to this screen.
I will try to pin point the problem to see if it's the battery or the screen or the camera (??)
. I'll let you know as soon as I can.
However, if the problem is the camera can someone explain why?? And how to fix it ?
Thank you everyone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sebastian Marschall 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 25
总计 6,521
