跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Liquid damage - Can't power on when unplugged
I've got a MacBook Pro that received a coffee bath. Everything seems to be functional aside from one odd behavior: when the computer is entirely off, I cannot power the computer back on unless I attach the MagSafe adapter. Once the computer is on I can disconnect the power and it runs fine. It even displays the battery percentage in the OS. Taking the computer apart, I noticed that the board that is part of the battery seems to have been soaked with coffee.
So my question is this: Given the behavior, does anyone here have a guess as to whether it might be more likely to be the logic board or the battery?
I can purchase a new battery and return it if I don't need it (for a refund, less return shipping and a 20% restocking fee), or I can go for a $200 repair service that may just tell me I need a new battery. I'm leaning toward trying the battery first...
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Unfortunately, it sounds like the motherboard is the issue. (from what I know), the circuitry in the battery only regulates voltage, and it's up the the motherboard circuitry to allow that voltage to come through to the system power, so in technical terms, it sounds like the regulator (ISL6259) for the voltage rail PPBUS_G3H only works when it's in a S0 power state.
That being said, I can only assume so much form the symptoms of the laptop, and without having the laptop in front of me it is hard to tell, so it might be best for you to take it to a 3rd repair shop that offers a no-fix, no-fee system that also does component-level motherboard repair. That way, then can isolate the issue for you, and if the issue is in the logic board, they can fix it for much cheaper than the cost of a replacement.
这个答案有帮助吗?
得分 2
2条评论:
OK, thanks for the info (including the technical bit). I'm sending it in to a company that offers a no-fix, no-fee repair service.
完成的
Okay, hope it goes well!
完成的
添加一条评论
添加你的答案
Kyle Combes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 106
