跳转到主内容
Model MD2614u / AMD Turion X2-64 2.1GHz dual-core processor
power surging and video disapearing
I have been working on this computer for a couple of days the HDD has bad sectors but the main problem is that when I power it on as it boots up it seems like it is loosing power or is being switched off repeatedly. Do you have any ideas what would cause this? I have tried pulling the ram one stick at a time, pulled the HDD reseated the processor and replaced the heat sink compound.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
Integrated video card may have overheated causing contact to partially separate from motherboard. Try to re-seat using enough heat to melt solder and regain contact.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem. I thought it was the processor overheating it turned out it was the video card. The thermo pad has become thin thus not making good contact with radiator. Replace with one of appropriate thickness and you should be good. Refurbished unit....
这个答案有帮助吗?
得分 1
添加一条评论
Check for a loose screw contacting the motherboard or between the motherboard and the modem card, especially if it was a refurbished model
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim Fox 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,596
