跳转到主内容
加入维修社区 - 创建账户
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
No flow from Power Head
The machine turns on; heats up; hot water works fine from wand; steam works fine from wand; but, while pump appears to be working, water will not flow through the power head (with or without the portafilter being in place). Thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
My first thought would be mineral buildup inside the power head. In this case it would need a serious descaling.
Scale normally forms while the machine is being used; descaling is necessary every 4-6 months of use or whenever you observe a decrease in water flow. If you wish to descale the machine yourself, you may use any commercially available non-toxic and/or non-harmful descaling agent for coffee machines. Warning! Never use vinegar as a descaling agent.
Mix the descaling agent with water as directed on the package and pour the solution into the water container; place the water container inside the machine.
Turn on the machine, Position the steam tube over the drip tray. Empty the entire contents from the water container at intervals (one cup at a time), by turning the steam knob counterclockwise; to cut off flow turn the knob clockwise. During each interval, allow the descaling agent to act for about 10-15 minutes. When all the descaling agent has been used up, take out the water container, rinse it out and fill it with fresh drinking water. Place the container back inside the machine; empty out 2/3 of the water in the container by turning the steam knob. Let the machine heat up and empty out the water remaining in the container with the steam knob.
If you have been using it for a long time without doing this a couple times a year you may have to do it more than once to fully descale it.
这个答案有帮助吗?
得分 1
添加一条评论
Have you removed the group head (what I assume you meant by "power head") screen to see if it's clogged? That's much more likely then a scale clog on these machines.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shep II 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 187
