跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
Digitizer replacement does NOT work!?
I recently bought an iPod Touch 2nd gen with a cracked digitizer. I have replaced many of these in the past, and have done many other numerous iPod repairs on all other iPod models.
So I took off the broken digitizer, and put it the new one. I did not secure it to the iPod Touch, just in case it wouldn't work. I then powered it on to test it. Of course it didn't work! My digitizer was OEM, and was purchased from the same seller that I had bought from before.
I had another OEM digitizer that worked in my house, and so I tried that one. Again, no luck. I then took it all apart, cleaned it, assembled it back together, plugged and unplugged the two different digitizers multiple times, and haven't gotten any response!
Any help? Anyone else have this same problem?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Sounds like more than the digitizer is broken, open it up and see if anything else is obviously broken.
这个答案有帮助吗?
得分 1
2条评论:
I looked, and nothing else is physically broken. It's as dirty as Satan in there though. That's partly why I unassembled it- to clean the iPod.
I sure hope it's not the motherboard. Those are worth more than the iPod itself! :(
完成的
It might be worth to clean it then.
完成的
添加一条评论
Yeah. I wish I had a tool to REALLY clean it. Any ideas?
这个答案有帮助吗?
得分 0
1条评论:
All I can think of is compressed air.
完成的
添加一条评论
Did something work?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iball1804 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 7
总计 4,930
