跳转到主内容
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75 个问题 查看全部
My controller doesn't work with batteries
My controller works but only with the USB cable plugged in. It will not work/turn on with batteries in. I have tried new batteries, clean metal conact in controller, updated via usb but still wont work with batteries just cable.
Does anyone have any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Make sure you hold the Connect button (on the XBox).
这个答案有帮助吗?
得分 1
添加一条评论
It could be a broken wire or solder joint to the battery port
这个答案有帮助吗?
得分 0
添加一条评论
If you continue having issues turning on your Xbox One Wireless Controller, check out this Xbox One Wireless Controller Won't Turn On Problem Page.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Григорий Сака 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 11
总计 3,405
