跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Activation problem iPhone 5s
I keep trying to activate iPhone did everything from hard reset to plug into iTunes over and over... The iPhone take you through all the activation steps to set up to the welcome to iPhone. I press get started and iPhone then goes inside the iPhone for like one second then black out goes back to Hello screen and then Activation Required pops on screen.. On iTunes it says iPhone can't be activated try again later.. Has anyone ever incountered this problem before?? Someone please help...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Does It Have A Sim Card In It?
完成的
try activating through iTunes if there is a baseband firmware issue then iTunes should recognize this in the restore process. the cpu sn. modem sn baseband memory or nand sn can cause activation issues
完成的
you can also download 3utools this will show you in the main window the capacity of memory, base-band firmware and iemi this tool also enables you to reflash but be aware the flash process could brick your phone but will identify the cause
完成的
Yes it has a SIM card and I've tried everything over and over in an attempt at activating the phone don't know what's going on???
完成的
Can you find the way to solve the problem so far? The problem occurred to me today. I tried everything and already read lots for forum about this but still can’t figure out how to fix it ..
完成的
显示更多的2条评论
添加一条评论
3个答案
已选择的解决方案
I'm surprised nobody ask this but do you actually see an IMEI number displayed when you tap on the blue circle i icon on the setup lock screen?
Sounds like the baseband chip needs to either be replaced or reballed.
这个答案有帮助吗?
得分 2
1条评论:
Yes, in my case the IMEI no. did show up.
I firstly thought it was a software problem. I don’t have time to actually take it back to the store yet but seemed that I have to do so if it is a problem with hardware.
Thanks for pointing out anyway.
完成的
添加一条评论
Take out any sim card in it. Connect it thru Itunes or 3 u tool and just flash it.
这个答案有帮助吗?
得分 1
添加一条评论
What is your iOS version. I heard of that if iPhone 5s on iOS 11+, it could not be activate. You can aslo try to activate your iPhone with 3uTools.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 3,167
