跳转到主内容
加入维修社区 - 创建账户
型号 A1418 / 2012 年末 / 2.7 & 2.9 GHz Core i5 或 3.1 GHz Core i7 处理器
iMac Will Not Turn On
I have a late 2012 iMac 21.5" that will not turn on. Black screen, no gong, nothing...
I've disassembled the iMac and looked at the diagnostic LED's and found that only LED #1 (at least I believe it is #1) is the only one that turns on. I then tested the power coming from the power supply which is giving me 11.79 volts on the following Pinout.
0 - ground
0 - ground
0 - ground
0 - 11.79 vdc
0 - 11.79 vdc
0 - 11.79 vdc
From what I read this is pointing to the logic board but I wanted to make sure from the Pro's out there in this forum. Shouldn't I at least be getting 12 vdc and not under that? I've watched it drop from 11.84 vdc to 11.79. Please see the following pictures to understand what I described above.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Did you end up fixing it? i have the same problem with mine
由完成的
添加一条评论
1个答案
已选择的解决方案
I see this question is backdated a bit and hasn't been replied to. I dont know if you still need input on this one or if its too late.
LED one indicates that the logic board is receiving a trickle charge from the PSU. when you push the power button, the second LED should come on, indicating that full power has been received, then the 3rd indicates the GPU initialising, and the 4th indicates the LCD is connected and enabled.
if you get no second LED, then i'd initially check that the power button hasn't been damaged.
You can start by unplugging it and shorting out the power pins.
If you still get no response, then it could be PSU or logic board, but its hard to trace without a process of elimination of some kind.
I hope this helps.
这个答案有帮助吗?
得分 4
6条评论:
Hi Jon
I also have a problem with mine.
It is a EMC 2544 Imac I believe a 2.7ghz
I has seen little use since it was purchased, and isn't left running when not in use.
Anyway it wont power on at all.
I haven't yet dis assembled it. This happened a few weeks ago, and after a couple of tries I was able to get it to boot.
I have tried the power on for 10 sec then again trick. I have also checked and tried different power cords.
I haven't contacted apple yet to get a quote on a power supply replacement.
I have seen the part online for around $130.00 any other tricks to try before I tear into this thing?
Thanks
Daren
由完成的
Opening is the part you want to be careful with. We recommend using the correct cutting wheel and tools for it. Apple made one, but so did iFixit, which is a great tool for getting the LCDs off. You'll also need replacement tape for when you rebuild it.
Diagnostics of a power fault, start with the diagnostics LEDs on the logic board. They are there to see how far the power is getting through the board.
But once you know the fuse is OK in the mains cable, and you've had intermittent boots recently, there isn't much else you can test without opening the machine up unfortunately.
由完成的
where I can buy online in Australia , logic board EMC 2544 imac 21,5”
由完成的
Not sure of any operators in Australia, but we ship to Australia from the UK.
www.thebookyard.com
由完成的
Hello Jon, I have a similar issue. Only the bottom LED stays green and nothing else happens. What can I do to see it is a faulty power supply unit? Thanks
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
steharmon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 2,726
