跳转到主内容
Horizontal lines on screen and 4 inches of left screen blacked out
TV has sound and picture but there are little black lines on the top of the screen like three bold black lines in the mid bottom screen and it looks like the picture doesn't go all the way across to the left side of the TV screen. What causes this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
I would suspect the driver board. Since you have a decent picture there, what's missing is the entire signal being sent out. That signal gets split into lots of ribbon cables at base or top of LCD panel and they then power the strips in the LCD.
One thing you could try to verify if ribbons are loose/bad or if video driver board is bad is grab the display at opposite corners, like left top and right bottom and slightly twist the case. If the display changes, gets better/worse, then the ribbons are suspect. If no change, then I would proceed to the driver board.
My bet is the board. Rare for those ribbons to come loose.
Mike
这个答案有帮助吗?
得分 0
3条评论:
I already changed the logic board. I will try to readjust the ribbons the tv screen did fluctuate when I flexed it.
完成的
What wood fry a ribbon on the botom of t con board. I plugged it back in and turned ot on and smelled smoke......?
完成的
Did you reassemble the case? Maybe a cable got stuck and a screw went through it. Check all the cable routes. There should be no real power going to the LCD other than power for the LED backlight so smoke is something else going wrong. Without seeing it I can't be sure now.
When you say it did change when flexed, did it just distort what you saw? Or did the areas where it was dead/lines come up normally briefly?
完成的
添加一条评论
添加你的答案
AL V. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,980
