it doesnt turn on and when I pluge the chager it turn on and off conti
my tab doesnt turn on.when i pluge the the charger it turn on and off continuesly. i can't get new one
it could be a battery issue or it may even be a port issue. a lot of times when we continuously plug and unplug things the ports become loose and will not work properly anymore. try plugging the charger in while the tablet is off and see if it charges. wiggle the plug around to see what angle it charges at and when you find the sweet spot leave it at that angle while the device is off and let it sit there for an hour and then come back to see if it is charged up some and try to turn it on. I hope that this helps you and that you are able to use your tablet again without having to spend any money.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 68
I think it is a problem of bagterry bu my mom doesn't buy a new one
由 Jayamal 完成的
