跳转到主内容
加入维修社区 - 创建账户
not responding screen black screen
hello,
i have bought new screen with the digitizer .. i had the iPad ready before the screen arrived it was working perfectly all i had to do is connect the cable for the new screen on the iPad and I'm done! what i didn't see coming is that the screen did not respond! its black i thought something must be not right with the screen so i plugged the old screen to check and it tuned out to work perfectly!!! when i tried with the new screen it still black and after a while the old screen didn't respond as well the new one either black or with lines .
what can i do ? what to replace etc!
Update (01/19/2017)
this is the screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
are you replacing the digitizer or the lcd? did you disconnect the battery prior to replacing?
完成的
添加一条评论
1个答案
最有帮助的答案
this lcd display in pic is shot. you will have to replace it with more care as the lcd panel is extremely fragile
这个答案有帮助吗?
得分 1
2条评论:
the problem is i bought it from the website and it came to me in the pic you see
完成的
hi Maryam then this has likely to have happened in the post due to the fragility of the LCD crystals in the display. it is not uncommon for us repairers to lift a lcd display working and replace it finding it damaged even with the up most care being used. the replacement will solve your issue thought and isolate the battery prior to replacing the display
完成的
添加一条评论
添加你的答案
maryam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 265
