跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
How to retrieve data from a Cracked and shattered screen.
My son decided to knock my phone down a couple months ago and cracked my screen 2 months later my screen quit working and 3 hours later started turning purple and now completely black. I have a password on it. Is there a way to retrieve the files, pictures and data off it? My SD card apparently didn't save everything and there stuff on my internal memory. I wamt to try to get the stuff back before i turn it in as i have important files on it. Anything welcome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Sorry it's not an answer I just posted it in the wrong place ...... I have the Samsung Galaxy S7 from Cspire and when I was looking for the parts I didn't see Cspire are what would work with it can you help ( Busted Screen ) black out.
完成的
添加一条评论
1个答案
已选择的解决方案
You have a broken LCD which is causing the issue with seeing anything. Replacing the screen will restore functionality for you but, as I'm sure you've noticed, this can be expensive!
You can use a data/charging cable connected to the computer or Using Samsung KIES.
http://www.samsung.com/in/support/useful...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alisha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,012
