跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
97 个问题 查看全部
Why wont my crv start
My crv was running fine then as we were going up a hill it died on us i replaced the battery spark plugs distributor cap and the main relay now it trys to start but wont its getting gas and i checked the timing one of them is slightly off could that be the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Has the timing belt been replaced yet? They should be changed every 100,000 miles. It maybe that the belt jumped a tooth. Not that familiar with hondas and unsure if can even do that, just a thought.
You said it's getting gas. If the fuel filter is partially clogged then it will show some getting to engine. But not enough pressure. Going up hills and dying is what I've heard most when a fuel filter is to blame. Due to the more demand for gas when pulling hills.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James garman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 119
