跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Touch ID not working with screen replacement but original home button
Hi all.
I can't seem to find any answers to this and it has me stumped.
I have replaced a display on a iPhone 6s but have carefully transferred the original home button to the new assembly but the touch ID will not work.
I have also removed the original lcd backplate from the broken screen and connected the home button to that and then that to the board with the same result.
Can anyone help me?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
i think you have damaged the FTP ribbon. i have seen this so many times. the ribbon has perforations at the top of the flex on the lcd part. check the perforations for breaks where it leaves the back of the lcd metal shield. good part is you can fit a replacement ribbon just not the actual button
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your reply. I don't think that is the case though. I was so careful when performing the replacement, and like I said in my original post, I even swapped it for the original with the same result
完成的
添加一条评论
添加你的答案
domhaywood 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 8
总计 129
