跳转到主内容
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
Exchange keyboard key hinge
Hi,
I had the P key stuck a bit and I tried to pry underneath it to remove some dirt. However I accidentally removed it and the hinge at the bottom side (where the key is hooked in) broke. I tried to remove the hinge to take a close look, but it looks like it is covered by the plastic of the key cap. I did not go further, but does anyone know, if the cap is glued and how one can remove it gently to reach and change the hinge?
The key still works fine, it just pops out at the bottom.
Thanks,
Duc
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You likely broke the key cap. I would take the system into an Apple Store and let them fix it. It should be still under warranty I wouldn't tell them what happened ;-}
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Duc Bao Ta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 698
