跳转到主内容
型号A1318,闪存容量:32及64GB
299 个问题 查看全部
What is the plastic surround?
I am trying to do the battery replacement. In the process the front glass cracked. I got it off, but am thinking now I have to replace it.
I read this in the guide:
. If the plastic surround is not flush with the front face of the glass panel, gently peel it off and stick it down.
What is the plastic surround? Is it on the front panel or in the back? IS it the thin rubber like thingie between the case of the front panel and the shiny back case? I don't know what to peel off and stick down if I don't know what it is!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
What guide are you following and what step of the guide is that from?
完成的
Front panel, step 8, third bullet point.
完成的
添加一条评论
1个答案
已选择的解决方案
The correct term for this part is mid frame bezel gasket. The digitizer glass is adhered to this with double sided adhesive and it is the part that actually snaps back into the frame. More likely than not you will need to replace it each time when removing the digitizer glass. You can buy the entire assembly pre assembled here:
iPod touch (3rd Gen) Front Panel Assembly
Good luck and please get back to us with how you did.
iPod touch (3rd Gen) Front Panel Assembly图片
产品
$29.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sunshine 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 4
总计 1,534
