跳转到主内容
Comprehensive set of repair manuals for Android tablets manufactured by Samsung Electronics.
Why is the time wrong?
I set the time daily on my tab. 4 10.1 and it will be wrong by 2 or 3 mins. the next day.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
10条评论
Had this issue where clock would show correct time however system time was in correct. To fix I selected automatic time zone in phone date time settings and then set the APN to correct option out of three which was Vodafone uk. The other and incorrect options which were causing the time problem were Vodafone prepaid and Vodafone post paid internet (may differ on your phone of course especially if not with carrier Vodafone but idea is the same). Hope this helps.
完成的
In addition to my previous comment about setting correct APN, setting the correct APN also strangely improved phone performance and fixed in car Bluetooth audio / music issues I was experiencing.
完成的
I have a galexy core, if I set it to automatic time set it changes the time and date Way off what is right, I don't live anywhere near a time zone and only use the phone on WiFi, how can I fix that?
完成的
Amazing, the simple APN update appears to have worked. This has been bugging me for months.
完成的
At least 1 or 2x weekly my samsing note 9 get the "incorrect time" error,
& stuff DOESNT WORK.
... & I have it set to AUTOMATICLY ADJUST time.
> Any idea WHY this is happening & how to prevent it from happening again??
(( "usually" after restarting the phone, it corrects itself
but its REALLY annoying.
If it doent correct itself i do it manually & tge switch back to auto, as i never had this problem using auto UNTIL RECENTLY).
Help
完成的
显示更多的5条评论
添加一条评论
6个答案
已选择的解决方案
Go to settings, then to date & time under system, and select automatic date & time and automatic time zone. This should fix your problem. I hope this helps.
这个答案有帮助吗?
得分 7
5条评论:
Thank you so much
完成的
I am using the Samsung Galaxy Tab4 and have the same problem with the date and time. I would just boot up and it would suddenly be totally out of whack. Happens at least once a day. Using the same method as you discribe, I reset it to the correct date and time and have noticed that even though that changed, the time zone did not and remained correct. How do I get this to stop? I don't always notice the time malfunction right away and it buggers with my appointment notifications.
完成的
Very simple with your directions. Thanks very much.
完成的
I fixed it by turning off the automatic which was preset at Atikoka In Quebec province and a more Eastern time zone.
The solution is to leave it off the automatic setting.
完成的
Mine's been 8 minutes fast for years, despite being set at London tiME - which should be correct as I live in the UK. Today however I did this and, at last, it has corrected the problem!
Go to settings - general management - date and time - auto select time zone (GMT for me). Sorted ?
完成的
添加一条评论
Amazing, but the simple apn update fixed it for me.
这个答案有帮助吗?
得分 2
1条评论:
Amazing but the simple app update fix it for me
完成的
添加一条评论
Go settings ,turn off auto matic time zone, options available time zone , and click, select country , India's any famous city came like Kolkata, delhi select Kolkata or other , click , and success
这个答案有帮助吗?
得分 1
2条评论:
My Samsung s10 plus time gets slower by 2 minutes. I've tried every possible ways to solve it but couldn't get it fixed. Can anyone help me please.
完成的
My husband is having the same problem. His is off by three minutes
完成的
添加一条评论
I live in Thailand and it is not indochina time zone.
It is wrong. Automatic time is not help.
Aliza
这个答案有帮助吗?
得分 0
添加一条评论
I am not finding automatic date & time on my Samsung Tab 4
这个答案有帮助吗?
得分 0
添加一条评论
My Samsung Galaxy Tab Pro was set to all automatic, it had the correct TZ, but it was Feb 2014! I turned off auto date & time and entered the correct date and tinme, turned off auto TZ, selected the same TZ offset in a different location (both GMT-8), re-enabled the auto switches, it went back to the 2014 date! I ended up leaving the auto switches off. Has anyone else seen something this crazy?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Bryson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 157
总计 79,542
