跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone 6 plus Touch Disease Repair Attempt Failure
Before any repairs, a piece of the battery connector fell off by itself. This strangely did not appear to affect the phone since it still turned on. I attempted to repair touch disease on my iphone 6 plus by replacing the smaller silver chip on the board. After replacement, the iphone 6 plus still did not have touch. I began to suspect the screen was simply seated incorrectly and I reseated the screen many times. After a few times, the screen turned blueish and slightly flickered if you looked very closely at it. I kept trying to get it seated properly and eventually the screen doesn't even turn on anymore! At this point im unsure if its the connector for the screen, the battery connector, or the touch ic chip i had replaced. I have only tried using a heavily water damaged screen on it and a "brand new" screen on ebay. I figure it cant be only the screen because both screens now appear completely black.
What should I do now?
The phone still connects to computer
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Update: now it turns on again with the weird blueish screen
完成的
添加一条评论
1个答案
I was going to upload a video walking through what to test but ifixit is retarded when it comes to uploading media.
I would recommend taking the new ic you installed off and powering the device on with no new cumulus broadcom chip installed. It should power on without the chip. This will let you know if the chip was installed correctly or if you accidentally bridged pads.
这个答案有帮助吗?
得分 0
3条评论:
Hi @mdrecovery
Just for my info, what happens when you try to upload media? I have never had the chance to upload videos only pictures etc. using the insert an image or video option. There is a media option in there so I'm wondering what happens?
完成的
You're unfortunately limited on the size of the video. Plus loading a video, even compressed, takes what feels like an entire evening.
完成的
Hi, Thanks for that. Something to remember.
完成的
添加一条评论
添加你的答案
Diego A 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 568
