跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Home Button Not Working
The main board flex cable that to the home button broke on one of the connectors, which in turn ruined the original home button(no more Touch ID). I pulled the cable off of an iPhone 6 that I know had home button functionality and tried an after market home button, to reveal no touch input at all. I tried a few different home buttons as well and none worked. Could there be something else wrong that I've overlooked that could be the issue here? I plan to order another main board flex and home button but any ideas in the meantime would be helpful. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Which part exactly got broken for home button connection? The home button extension cable connector on the logic board? The home button extension cable teared? The home button cable itself got ripped?
完成的
Alright thanks y'all!
完成的
If you go to setting / general / accessibility turn it on then you get the home button on your screen . Works just like the real button..
完成的
添加一条评论
2个答案
已选择的解决方案
Yeah, im with Ben. You're post is confusing. If you need the extension cable, you should be fine. I order those moderately frequently
iPhone 6 Home键 线缆更换
iPhone 6 Home Button Link Cable
But you have me confused, what do you mean broke on one of the connectors? You mean the sockets? On the top of the logic board?
One of these?
iPhone 6 Home Button Link Cable图片
产品
这个答案有帮助吗?
得分 3
6条评论:
Sorry didn't mean to be confusing. The home button link cable fell apart at the connector closest to the home button (logic board is fine). In trying to disconnect the link cable from the home button, the connector fell off of the home button as well. So I took a new home button, and a new home button link cable and installed them, but home button functionality didn't return
完成的
Right, and you said the "new" parts, were known good?
完成的
Link cable was known good, pulled it from my persona phone and tried an after market cable. I also tried two different home buttons that came right out of the packaging. I suppose they both may have been defective but I'd like to hope not
完成的
Sounds unlikely the two new buttons would be bad. @refectio can I get a second opinion on this?
完成的
If the two buttons came in the same batch, perhaps they could both be defective...especially if the seller is on eBay or AMZN.
It's hard to see anything else wrong from this perspective.
完成的
显示更多的1条评论
添加一条评论
Hello Matt. So sorry to hear about your problem, unfortunately i have some bad news for you. Every single home button on the iPhone 6 and up has a small chip on the flex which has a kind of special code that matches with your motherboard. If you replace the home button, the motherboard will recognize that that part is not the original home button. There for it will never allow you to use the Touch I.D again. Not only that, if you ever try to restore or update your phone, it will get stuck on the "connect to itunes" screen. And every time you try to restore it, it will not fully restore, and it will give you the hardware issue error code. So then your phone basically becomes a brick. So hold on to that flex cable with the little chip in between the button itself and the plug in part. If the chip is still connected to the plug in, you might be able to un brick your phone, if you ever restore it or update it. Unfortunately your touch i.d will never work again. So sorry to have to be the one to tell you. This is one of the most annoying things to happen on an iPhone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt Primerano 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 326
