What's the Pinout to go from the camera's 6 wires to the POE Cat RJ45
MY Lorex LNB4321 camera stopped working, it had gotten water in the cable connection and the female RJ45 molded end had corroded away. I called Lorex but they wouldn't tell me the pin out to replace the end. I know the red and black go to the power plug but I need to know the which cat5 wire corresponds with the wires from the camera.
(gray, brown, purple, blue, orange, yellow)
19条评论
Need help to but my Cam has
Red, black, yellow, blue, white, green, orange, brown
由 James 完成的
I have the same Problem here is my fix Flir 2MP model No N133ED
Orange <--------> Orange
Yellow <--------->Yellow
Brown <--------->Brown
Purple <--------->Purple
Blue <------------>Blue
Gray<------------>Gray
Run Test and is all working for me
由 Hnova 完成的
Thank you so much the problem resolved ,great
由 mnh.yafae 完成的
I am so lost here. Can someone break this down for me as I have the same problem.
由 david.c.harrington 完成的
David, what camera do you have. The pin outs are different. But if you need to kind of know what to do if you have the correct pin outs I will be glad to help.
由 sscholton 完成的
显示更多的14条评论
