speaker woofer connector on logic board
The speaker woofer connector cable connot be connected to logic board because the connector on the logic board broke. Can this be sodered. It looks like there are four tiny connections on the cable.
it can be done, if you have access to BGA soldering equipment...
it is almost professional machine used for reflowing GPU chips. also, it can be used for all sorts of component repair...
这个答案有帮助吗?
I actually use a 3M tape (stick on top) and use 2 layers and use the cover to push the 4 pins to the logic board and it works so far.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 847
