跳转到主内容
Sony Xperia Z3 Dual also known as Sony Xperia Z3 D6633 is announced in September, 2014. It features 146 x 72 x 7.3 mm (5.75 x 2.83 x 0.29 in) body, IP68 certified, 5.2 inch display and 20.7Mp rear camera.
27 个问题 查看全部
Why is the device booting itself every 2-3 seconds?
I was using my Sony Z3 Dual at 12% battery. I opened Snapchat and then suddenly the screen flashed and started rebooting on its own every 2-3 seconds. I have contacted Xperia Care and they suggested me to charge the phone up to 80% and perform software repairs using their pc companion.
However on charging the phone i have found an issue that the charging LED (red) is blinking with the screen and does not remain on. I charged for approx 1 hour and was expecting the red led to stop blinking and change into orange led (indicating battery% above 15) which did not happen. On removing the charger the device stops rebooting which i assume that it ran out of its juice implying that no charge got in and the charge that got in was used to boot the device for the instant.
Please help me in finding a solution
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you tried connecting your phone to the computer and launch the phones fastboot mode if you haven't try it fastboot works independent of your system boot and can charge your device to a full 100% and if you have tried and nothing works you might have a broken or a shorted battery
Hope this Helped you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Farzeen Haneef 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 5
总计 135
