跳转到主内容
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
53 个问题 查看全部
Built-in flash will not pop up when required. error message appears
Built-in flash will not pop up when required. error message appears.
Camera may have been dropped while in its case. (Report from grandchild is sketchy)
It will take pictures outdoors when flash is not called for and indoors in sports mode.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
had a similar issue on 40d. brought it to repair shop and the guy just gently helped the flash to pop up with a fingernail and it jumped right out.
apparently the mechanics are very subtle a even tiny drop of something sticky might cause that the flash doesn't pop out. then the error message comes.
wouldn't use much force though, might be other issue
这个答案有帮助吗?
得分 0
添加一条评论
I have this problem too. I can manually pull the flash up but have to do it every time I take an inside picture. Any suggestions on how to permanently fix?
这个答案有帮助吗?
得分 0
添加一条评论
I had the same trouble with my T3-i. I used a small file to enlarge the hole that the clasp uses to hold the flash down. I did this extremely carefully as to not remove too much of the plastic, so that the flash would still be held down when not in use. I did this about 3 years ago and it has not caused me any trouble after the repair and it only took a few swipes of a file.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Lauritsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 481
