跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
Logic board or Psu?
I have a mid 2007 intel iMac 20" that won't power on. When I plug the ac adapter in the first led comes on. When I press the power button led's 2 and 3 come on and the fan spins at regular speed and the optical drive starts up. Led 4 never comes on so I think its an LCD or video card problem. Do I need to test the Psu or is it the logic board or the video card? Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try plugging in an external monitor, it could be the inverter... if nothing shows up, its the logic board. It would be unlikely that the problem is the PSU as your computer does start up and shows LEDs (which means it can process.. to an extent)
这个答案有帮助吗?
得分 2
2条评论:
If I hook the external monitor through mini-dvi, will the iMac automatically recognize the external monitor when it boots? Thanks for your reply!
完成的
If the LCD or the inverter is broken, the monitor should work, if it doesn't work, that means its the logic board thats shot (most likely)
完成的
添加一条评论
添加你的答案
Jonathan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,228
