跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
FF Camera Halo After Digitizer Screen Replaced
Successfully replaced the Digitizer Screen assembly, but there is an opaque crescent shaped halo around the outer edges of the front facing camera. I'm thinking it may not be pushed all the way in its recess. Any other ideas before I go back in digging?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I opted to move the camera over from the cracked screen feeling like I wanted to keep as many genuine Apple parts as possible that I knew were fully tested and functioned perfectly. Saving $10 wasn't the real motivator, but it didn't hurt.
My assumption is similar to yours. Perhaps the camera is not quite snapped into it's retaining socket as it needs to be. I believe the symptom would be more severe if it were an electronic problem. The slight halo along the left edge is a nuisance more than a serious issue.
完成的
添加一条评论
1个答案
已选择的解决方案
Did the replacement screen come with the camera pre-installed or did you move it over from the cracked screen?
If you moved it, chances are it's not lined up properly. Follow this guide to insure everything is in the proper position.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
gybeho 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 131
