跳转到主内容
The Lenovo P2 is also known as Lenovo P2 P2a42, Lenovo Vibe P2. The Lenovo P2 is an Android smartphone released by Lenovo in November 2016.
17 个问题 查看全部
Speaker suddenly less loud/lots of noise
Hello,
The speakers of my Lenovo p2 are suddenly broken. The sound coming out of the speakers are much less loud and crackling. As if the speakers are covered by a seal or something.
Have tried it in safe mode and the problem still exists.
Do you have a solution for this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
What happened prior to this happening?
Example: Has it been knocked, dropped or near any strong magnets?
这个答案有帮助吗?
得分 0
1条评论:
Mine looks like the 3.5mm jack issue. When I remove the plug, it make bad contact to speaker. Sometime if I blow the hole, it become good for a while.
完成的
添加一条评论
Hello answer is very simple, holes are too big and gets dirty if you us a small niddle gently you’ll be able to remove it, it’s going to sound loud again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeroen vR 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 2,482
