跳转到主内容
First generation of Citroen's supermini car.
Reversing light comes on occasionally when breaking
Since having my reversing lights repaired at a garage, they come on occasionally when I break. Drivers behind me are worried! I can't recreate the fault when stationary tho. Help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
does the reverse light work when you have it in reverse gear??
完成的
Yep, reverse light works when in reverse gear and I can see it when it's stationary
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
If the work was carried out recently to repair the reversing lights by a garage, there should be some sort of guarantee on their workmanship, provided by them, even if it is only for 30 days etc.
Take the car back to them and explain the problem and show them as well (hopefully the problem will happen when you do this) and ask them to check it out, as it is causing problems for you..
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
sophie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 264
