跳转到主内容
Can switching regulators cause interference on wifi based circuits?
I read that buck and boost converter due its switching mode produces too many noises compared with linear regulators but it is more efficient.
Can those those noises cause interference on boards with wifi chips on it?
How would be a good way to measure how big would be such interference at the point to determine that it is worth to use a linear regulator even without power efficiency?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi, This might be a good starting point.
http://www.ti.com/lit/an/slva219a/slva21...
完成的
添加一条评论
1个答案
已选择的解决方案
I am not an electronics engineer but it is correct to say that SMPS are inherently noisy. Linear Regulators, when properly designed are not.
That said, applying proper filtering and EMI reduction are key to proper product design. A good example is smartphones. They have multiple SMPS cohabiting with WiFi and other radio frequency devices all on a single (and tiny) pcb.
Generally speaking, PS requirements are based more on power and heat dissipation than EMI because you can always filter out noise but you can't eliminate heat.
Not sure if this helps or not...StackExchange or EEVBLOG Forum is probably a better place for this question.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
AmandaLi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 130
