跳转到主内容
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 个问题 查看全部
How on earth do I reconnect the P9 ribbon cable?
I have tried it a million times! I cannot for the life of me figure out how the ribbon cable goes back into the connector on the motherboard! What am I missing? All of the YouTube videos I have watched have effortlessly slid it into place, but it almost feels like a wall has been erected in the slot the cable is supposed to enter into! Has anyone experienced anything similar? Any advice on what I am missing?
( The P9 is either for the camera or the speakers if that helps to identify it)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Is the connector ZIF (zero insertion force) or LIF (low insertion force)? ZIF connectors have a latch that you lift before you pull a cable out. You can remove a cable from a ZIF without opening the latch but it is better to open the latch before removing ribbon cable. LIF connectors do not have a latch, the cable is pushed in and held by friction of the connector.
这个答案有帮助吗?
得分 3
添加一条评论
Had the same problem. It's very difficult to get the cable back in with the ds closed as the cable will be fighting you the whole way. If you open the top screen the cable lines itself up better and goes right in.
这个答案有帮助吗?
得分 2
1条评论:
This definitely makes it easier to put the cable back into the latch
完成的
添加一条评论
Open the latch and stick the ribbon under the latch.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 27
总计 1,153
