跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
two white dots on the top left corner
I have attached an image of the dots.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
最有帮助的答案
It's the LCD. Did you see if Apple will replace it for free?
这个答案有帮助吗?
得分 2
添加一条评论
Is it still there when you change the back ground?
I suppose it isn't superficial and can't be cleaned off?
I suspect however that it was pressured in those two spots killing the led pixels there.
If it's still under warranty take it in for a repair at an Apple Store. If you are not near an Apple Store you can send it in for repair. Any warranty issues should be covered at not cost to you (other than shipping fees). However, if you are no longer under warranty then you can have the touch screen replaced by yourself or a 3rd party. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
It’s not screen or pixels. Shows only on home screen and not when u use apps.
这个答案有帮助吗?
得分 0
1条评论:
Mine shows one white dot and on google search. And home screen. Not while using apps. Any answer as to what this could be?
完成的
添加一条评论
I just the same issue with the iPhone X, I just re-started the phone and now they are gone! (press the low volume + Power Button) - hard power off.
这个答案有帮助吗?
得分 0
添加一条评论
I have an iPhone 6s Plus and just had the exact problem… Read about kikexxx69’s answer and did the same and the dots are gone
这个答案有帮助吗?
得分 0
添加一条评论
It’s the start/stop dots when you select text on the iDevice.
They get stuck on screen for some reason
Power off /on will fix it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wyskippy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 19,087
