Charger broke off in the charger port! Any idea on how to get it out?
The charger broke off in the charger port and was wondering how I could get it out?
Charger what broke off? The plug? If there was enough force placed to break it off, I'd say the internal receptacle is most likely damaged as well.
One trick I use to get plugs out is to get some Silly Putty. Squish it into the plug, then quickly yank. It might not come completley out, but it should get it out far enough to get some tweesers or needlenose pliers in there.
Other than that, without a pic showing exactly what's going on I can't really give a more detailed answer.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 0
过去的30天: 15
总计 1,348
@ebane0314 You should post an image so we can see what you are working with
由 Jetlabb 完成的
