跳转到主内容
华为2016年旗舰智能手机。拥有一体成型机身以及徕卡设计的双后置摄像头。拥有32/64 GB存储空间以及6种不同配色。包括型号有 EVA-L29, EVA-L19, 以及 EVA-L09.
72 个问题 查看全部
Camera and led not working huawei p9
Recently, i broke the screen and had the LCD digitizer replaced by a local guy. Upon replacement, the screen itself did not sit completely flush and there was a small glimmer of light that you can see through the side of the digitizer; no biggie all seemed to be fine.
however now the LED does not work (i open the flashlight app and nothing happens), Nor does the camera app work. When I open the camera app, the app dies and doesn't open. When i try an app that would USE the camera, there is an error message saying "the camera is in use by another application".
So-- I'm unsure if the camera or LED worked prior to replacing the screen. I honestly didn't think to check. The screen was damaged pretty badly.
Ideas.?
I have called Huawei US and as this model (the p9) is an "International model" they (Huawei) will not help. Which is weird. but alas true.
I know that this phone is not in the US yet, but it seems that if I can't fix it, it is a big risk to buy another knowing that if I break the screen, im screwed.. any ideas..?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I have the same problem but after a battery replacement. The flashlight works however, but I had to activate it from the lock screen the first time (it was blacked out in the notification/quick settings)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chuck Colby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,511
