跳转到主内容
加入维修社区 - 创建账户
2015年三月发布的MacBook 11吋使用第五代intel i5/i7处理器,並且拥有比前代稍佳的性能与电池寿命。
No backlight -- looking for real source of problem
Hi. I have 2015 MBA 11" with no backlight due to water damage. Other than the backlight, it appears fully functional (including LCD).
After cleaning and inspecting the logic board (820-00164-A), I found broken backlight fuse (no continuity), apparently no short to ground on both sides of the fuse and screw holes (no beep), and LVDS connector with heavy burn on the backlight side (side towards the backlight fuse). So, I am planning to replace these components.
Is there anything else that I should worry about?
Thanks for your help!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Nope. Just replace the LCD connector if burnt, will need to replace the LCD cable too (usually the plastic melts around the gold pins, or the gold circles on the bottom of the LCD cable are dull, which can blow the connector). I have not seen a MacBook with burnt LCD connector, where I have been able to confidently plug the old cable in, this usually gets wrecked.
When replacing the cable, be careful when removing the silver screen bezel at the bottom, to make sure you don't cut the screen ribbons.
这个答案有帮助吗?
得分 3
3条评论:
Thanks. I pulled the connector without knowing that. Will see what happens. Is the fuse for this model 0603 3A 32V? Also, when soldering the LVDS connector, do I need to solder the terminals on the bottom (not talking about the many pins sticking to the side)? I don't even know if they are "terminals" though... Thanks for your help!
完成的
Yes that is the fuse. Are you talking about the 5 dots under the LCD connector? You don't need to solder these, just the pins and the sides of the connector
完成的
Yes those 5 dots across the bottom of the LCD connector. Thanks !
完成的
添加一条评论
添加你的答案
NPA 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 21
总计 372
