跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Is it a burnt LCD and is there a solution?
I have several S6 Edge phones that seems like it was used as a demo phone in stores.
The same words and page is stained when it is turned on. Is it a burnt LCD problem?
What are my options to fix it and what is the cheapest way to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Unfortunately AMOLED displays are known to do this and are susceptible to it, and there isn't a fix besides replacing the displays themselves, it's known as screen burn-in.
这个答案有帮助吗?
得分 6
2条评论:
Thank you! I wanted to know what you call it. When you said "replacing the displays," do you mean the whole screen and LCD?
完成的
Yes, the entire screen/AMOLED, but it's too costly so wouldn't be worth it.
完成的
添加一条评论
Sara,
Question is not clear enough to answer, anyway demo units comes with limited hardware and specially customized demo software. even demo units doesn't have radio network access baseband chip|Modem to access the radio networks such as 2G,3G,4G. you can only able to use WiFi. spending money to fix demo unit doesn't make any sense
这个答案有帮助吗?
得分 2
1条评论:
Good to know! Thank you.
完成的
添加一条评论
添加你的答案
Sara 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,715
